Author Topic: Floor Grommets  (Read 945 times)
Offline k4ith
Floor Grommets
« on: 16 December 2008, 18:29 »
My car came back from the welders with a new ventilation hole :grin:. I have been told its a grommet hole - you can see the top of it in the bottom left hand side under the hole. Now why is it there? and how can i fill the fecker so as i dont have a flintstones car( think about it :wink:) any advice much appreciated.
MKV Golf GTI Edition30, GIAC Pump&Race Map, AutoTech Fuel Pump, R32 Front Brakes, Dbilas Flo-master Intake, S3 Intercooler.ECS Dog Bone Insert.
MKII GTI 8v Tornado Red 88 - Das Projekt
Offline jacko16v
Re: Floor Grommets
« Reply #1 on: 16 December 2008, 18:34 »
The two mk2's i've had have both had this, either bung it with a rubber bung or weld a plate over it and then under seal it.
Offline JC
  • Back in the North.
Re: Floor Grommets
« Reply #2 on: 16 December 2008, 22:27 »
that should be a round hole
as per
only way you can cure that will be as stated, a plate welded in and a good rust proof then underseal  :wink:
