Author Topic: can ant one help??????????  (Read 886 times)
Offline bazzza
« on: 16 December 2008, 15:06 »
hi what it is i was gettin water in my oil so i changed the head gasket an water is still gettin in my oil  do u think the head is fu*ked  as there is no power lost"d mmmmmmm1,8 8v
Offline Benrevs
Re: can ant one help??????????
« Reply #1 on: 16 December 2008, 15:12 »
Did you check if the head had broken down in anyway whilst you had it off?  Also what extent did you go to when re-fitting.. ie cleaning off the surfaces etc??  Also I think you have sticky M and Z keys. :grin:
Offline Horney
« Reply #2 on: 16 December 2008, 15:15 »
Sounds like your oil cooler has croaked and is letting water into the oil and vice versa.
Nick
Offline bazzza
« Reply #3 on: 16 December 2008, 16:06 »
when i had the head of i cleaned all the surfaces, an looked like no  damageto the head!   but the gasket had broken down a bit am goin to get a new oil cooler an see what happends,, confused . com?
