Author Topic: Speedometer Needle Dance  (Read 5012 times)
Offline Ben Lessani
Re: Speedometer Needle Dance
« Reply #10 on: 16 December 2008, 21:17 »
Mines only +/- 3mph, so its unlikely I'll make a boo boo.
Offline Mr Blue
« Reply #11 on: 16 December 2008, 22:15 »
Dont bother greasing it. Replace it as its cheap and easy to do.
The cable will look mint but its probably full of rust :angry:
« Reply #12 on: 17 December 2008, 11:06 »
DO bother greasing it, its free and it just might work! if not, it aint cost you owt eh ;)
Offline Goops
  • mk2 gti 16v
« Reply #13 on: 17 December 2008, 12:14 »
Cheers fellas, will wd40 it up on the weekend and see how it goes  :smiley:
Offline Ben Lessani
« Reply #14 on: 17 December 2008, 13:02 »
I'd be inclined to use actual grease, WD40 can be a bit thin, CV/Moly/General Purpose should do the trick.
« Reply #15 on: 17 December 2008, 14:06 »
trouble is its getting the grease in there, not like you can split the cable in half and grease it up!
Offline Ben Lessani
« Reply #16 on: 17 December 2008, 14:13 »
I have a plan, convince the missus that cv grease is a new rejuvenating creme and fill the bath with it, then drag the cable through it repeatedly until its full of it?
... Or use something like this, or lithium bearing spray.
Offline OakeyDoak16v
« Reply #17 on: 18 December 2008, 01:45 »
I think the WD40 is a good idea as it might just shift enough crud to stop it sticking, although do agree it may not last for ages. Deff worth a try. :smiley:
