Author Topic: Wheel spacers  (Read 1610 times)
Offline paladin
  • Call me old and I'll smack the sh!t out of you.
Wheel spacers
« on: 11 June 2004, 22:48 »
Just bought wheel spacers for my Mk3.
I'm running w/ the stock 14" alloys, and measured it a bit (by eye and w/ my finger)
and bought 8mm for the front and 20mm for the back.
Anyone w/ experience, is that too much?
It's a real pain to measue it the right way (putting washers in, catching the wheel bolts, then measuring them when it's right)
I can't return them after I put them on...
« Last Edit: 11 June 2004, 22:49 by paladin »
'94 Mk III 2.0
Bosal cat-back:K&N w/mod.airbox:GIAC
Alpine 9815
JBL BassPro
CDT Audio HD-52 in reinforced q-form kicks
MB Quart 218.21 (mid's) in rear
QuietCar (being applied)
vwsystems
Re:Wheel spacers
« Reply #1 on: 14 June 2004, 01:33 »
if your using wheel spacers use the proper ones......
there are cheap ones which are not balanced and the car wont drive properly!
theses may look like this
see how they dont line up properly and also they dont sit on the hub so you get run out problems!
the proper ones look like this
see how the holes are evenly drilled! and the proper ones sit nice on the hub!
if you use the ''cheap'' ones ie universal then you may aswell pull all the balancing weights off your wheel because thats exactly what your will get by using cheap spacers..... runout and loads of vibration problems!!
i didnt know about the spacer things as a bloke give us some for the wheels a mechanic told us and we took the spacers back for the bloke to say they were safe!!!!! after 10 seconds of us saying there unsafe the bloke said i dont need the greif you can have a refund! so he had the alloys back aswell!!!!!!!!
you may already know this spacer thing but most people dont!
abit of info for you!!!!!!
« Last Edit: 14 June 2004, 01:35 by vwsystems »
