Author Topic: Snap..crackle!  (Read 1284 times)
Offline Goops
  • mk2 gti 16v
Snap..crackle!
« on: 15 December 2008, 12:22 »
Started up the valver in the morning and she was "missing" slightly on throttle..
Anyway drove for about 5 minutes and it wouldnt stop doing this, opened the bonnet on the hardshoulder and heard this crackling..
Ther was sparks jumping between the 2nd sparkplug and inlet manifold??
I cleaned up with a cloth and wedged the rubber sideways and this stopped it.
Whats the cause of this? Moisture buildup?  :huh:
Do i need to replace the plugs?? :undecided:
ta in advance!
Offline Diamond Hell
  • Opinions я Us
Re: Snap..crackle!
« Reply #1 on: 15 December 2008, 12:38 »
Sounds like new leads needed, rather than anything else - it sounds like the shielding on them has broken down.
Offline Conker
Re: Snap..crackle!
« Reply #2 on: 15 December 2008, 13:03 »
As per DH... When mine did this, the insulation on the leads had failed.
Offline russ-vdub
  • Once a Dub, Always a Dub
Re: Snap..crackle!
« Reply #3 on: 15 December 2008, 13:10 »
As above, insulation. Quick fix is some insulation tape if you got some handy.
DH i'm not fond of you but your sig is absolutely legendary!
Offline Goops
  • mk2 gti 16v
Re: Snap..crackle!
« Reply #4 on: 15 December 2008, 17:44 »
Cheers peeps!
I will have a look at this over the weekend, insulation tape it is for now!
