Author Topic: Fault Codes from my car. VAG-COM might have saved the day.  (Read 4815 times)
Offline flex
I just bought one of those diagnostic leads from eGay and run it up in vag-com it came back with quite a few error codes which i have listed below:
VAG-COM Version: Release  311.2-N
Chassis Type: 1H - VW G/J/V Mk3
Scan: 01,02,03,08,15,25,56
Address 01     -------------------------------------------------------
   Controller: 037 906 024 BE
   Component: DIGIFANT 3.2        1953
2 Faults Found:
00525 - Oxygen Sensor (G39)
            03-00 - No Signal
00513 - Engine Speed Sensor (G28)
            27-10 - Implausible Signal - Intermittent
Readiness: N/A
Address 03     -------------------------------------------------------
   Controller: 3A0 907 379  E
   Component: ABS/EDS ITTAE 20 GI V00
   Coding: 03704
   Shop #: WSC 00000
3 Faults Found:
01276 - ABS Hydraulic Pump (V64)
            16-00 - Signal Outside Specifications
00287 - ABS Wheel Speed Sensor: Rear Right (G44)
            35-00 - -
            16-10 - Signal Outside Specifications - Intermittent
Skipping Address 15-Airbags
Address 25     -------------------------------------------------------
   Controller: 1H0 953 257  B
   Component: IMMO VWZ3Z0T2358765 V00
   Coding: 09600
   Shop #: WSC 00000
No fault code found.
End   -------------------------------------------------------
I think the most serious of these is the "00513 - Engine Speed Sensor (G28)" which is probably the reason the car wont start. I was thinking of clicking on the "Clear all DTCs" button to clear the errors (i think thats what it does) and then trying to start the car again. Will this give me a better idea of the fault as im worried some of these are old faults that were never cleared, do you think this would work and do you think that the engine speed sensor is likely to be my problem (original thread here: http://www.golfgtiforum.co.uk/index.php?topic=81906.0 )
Offline boneybradley
  • Back in a Mk3...
Re: Fault Codes from my car. VAG-COM might have saved the day.
« Reply #1 on: 04 April 2008, 21:34 »
test it again afet a few miles and the see what shows up... all old codes could be stored if they wern't erased and all the cars i've done a fault check on have had less errors after the second read.
Offline flex
« Reply #2 on: 04 April 2008, 21:48 »
sorry for doubling up my posts but i really need as much help as i can get. The problem is i cant drive the car as it wont start, so all i have to go on is the current fault codes.
  • Back in a Mk3...
« Reply #3 on: 04 April 2008, 21:55 »
the problem is the codes could be old..
but this code 00513 - Engine Speed Sensor (G28)
could be just the wires and worth checking... otherwise its a new sensor (crank angle sensor is common name) and this is located behind the front engine mount under the oil filter housing and the other means a lambda sensor issue and an m.o.t place can test this.
oh and it sounds like you've got a faulty abs sensor too!! again check when it runs ok and if the fault reappears
Offline cs98sss4
« Reply #4 on: 04 April 2008, 23:37 »
Hi,
Error 0513 - Engine Speed Sensor (G28)
Thats the engine speed sensor, had the same problem recently VW wanted £150 for the part I bought the GSF one and its fine.
If you have the budget for it I would get the seimens part from eurocarparts for approx £70 as thats the same one as the genuine VW. I only realised after I took the old one off.
Simple to change as well, just need to take off the front engine mount and starter bolts.
HTH.
Sukhvir
Golf MK3 16V ABF "Anniversary"
Offline filthy
« Reply #5 on: 04 April 2008, 23:39 »
If the wires are bare on one part of the sensor cable, then chances are they'll be knackered all the way down...I had to replace my sensor 'cos every time i stripped of the outer casing, all i found were bare wires...
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
Offline flex
« Reply #6 on: 05 April 2008, 18:14 »
Hi,
HTH.
Sukhvir
Cheers dude, without u mentioning the engine mount and starter bolts i would of had no idea how to get the f##er out. Took me long enough as it was, cant see any odvious defects but im gonna change it.
Where is the quickest place i can get one?
Offline mark3valver
« Reply #7 on: 05 April 2008, 18:55 »
mate - i know the non starter will be your biggest concern atm but I would do that abs sensor sharpish too.
MK3's have no brake bias - they rely on the ABS to not overload the rears so they are pretty important.
good luck with the ESS...
want a pair of raceland buckets with model specific subframes for £150 delivered? go here
http://www.golfgtiforum.co.uk/index.php?topic=83910.0
Offline flex
« Reply #8 on: 07 April 2008, 19:49 »
Cheers dude. It was the speed sensort in the end :D Its now running and idling better than it used to!
As for the ABS issues, i think they are old errors that need to be cleared however the software i have got will not clear them.
Me log now looks like this:
   Coding: 03704
   Shop #: WSC 00000
2 Faults Found:
            35-00 - -
   Coding: 09600
   Shop #: WSC 00000
Thanks for all your help!
