Author Topic: exhaust clamp position, could this cause a banging?  (Read 1074 times)
Offline gtiscott
« on: 10 February 2008, 16:01 »
Hi, as the title, could the position of this clamp(see pic) so close to the metal cross thing be causing a banging noise my car has? would changing all the rubber hangers lift the exhaust up to stop this or should i loosen and move the clamp?
cheers for the help
scott
Offline saul79
Re: exhaust clamp position, could this cause a banging?
« Reply #1 on: 10 February 2008, 16:16 »
yes just move the clamp ,new rubbers will make a difference ,try and twist exhaust-to straighen it up :smiley:
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline gtiscott
« Reply #2 on: 10 February 2008, 16:38 »
thanks for the reply saul, i will give that a go tommorow
Offline Mikester
  • Civic Type R
