Author Topic: wheels and tyres golf cabriolet  (Read 1625 times)
Offline richo
« on: 30 March 2004, 18:49 »
want to put bigger wheels on than the standard 13s  could do with a little help with size  15/17  and tyre sizes .the car has standard suspension. thanks
Dinky
Re:wheels and tyres golf cabriolet
« Reply #1 on: 30 March 2004, 19:13 »
Mine below r 205/40/17-dont know wot make off the top of me head(were on wen i got em) n the suspension is standard-needs lowerin! :D only goin for a 35-40mm drop thou!Dont want no scrappin!
Dinky  :-*
Offline richo
« Reply #2 on: 30 March 2004, 21:34 »
does your wheels have spacers as i tried similar size wheels but were very close to hitting springs
Offline Danr
« Reply #3 on: 30 March 2004, 21:52 »
Buy mine off my mk1 in my sig pic, there 16" on 215/40 tyres, barely done 1500 miles, i want smaller as going for an old school look  ;D
Offline AdamB
  • The Perfect Storm
« Reply #4 on: 31 March 2004, 07:54 »
I used to have 205/40/17 with a drop of 40mm, but this caused slight rubbing under hard cornering, then I changed to the current "old skool" look with a set of 14x8 195/45/14 up front and 14x9 215/40/14 rear, but these stick out past the arch, and need to have stiffer suspension to prevent the back tyre clipping the arch. this had also dropped the car another 40mm due to the decrease in wheel radius. With the extra 50 mm I need to drop the front with the coilovers I have got a total drop of nearly 130mm from the original ride height.
I'll let you know next week how this all works with the new set up.
Ads
I don't own this anymore - I just can't be arsed to change the picture
