Author Topic: Heater Switch problems  (Read 2136 times)
Offline M41K1T
« on: 19 February 2007, 15:27 »
Hi
I have just turned my heater switch on and nothing is happining, it was working fine yesterday, any1 have any ideas?
Cheeers
« Last Edit: 19 February 2007, 15:49 by M41K1T »
Offline gibby
Re: Heater Switch problems
« Reply #1 on: 20 February 2007, 14:30 »
Could be a blown fuse or it might have a loose connection on the switch, wiggle it about a bit and try it again.
......now officially dubless.
Offline M41K1T
« Reply #2 on: 20 February 2007, 16:09 »
Hey Gibby
Tried that no luck  :cry:
any ideas wot else it could be?
« Reply #3 on: 20 February 2007, 16:39 »
does it work on speed 3? if so the resistor on the motor has shafted.  When was the last time you used it, the motor bushes may have siezed, spray a ton of penatrating oil on em whilst wiggling the fan blade :)
Offline M41K1T
« Reply #4 on: 21 February 2007, 16:55 »
cheers will give that a go now
Offline caddyrage
« Reply #5 on: 22 February 2007, 16:04 »
Had the same prob on my caddy. The resistance wire burned out on the plastic heater motor cover :angry:. Swapped the wire and fuse and it works again. Let me know if you need the parts..... wire, switch or motor as i have spares :wink:
03 ibiza PD 130 sport, smiles per miles!
83 mk1 golf gti, 16v 2L PL
92 mk1 caddy, now stripped for resto
WWW.FENDUBBERS.CO.UK
cambridgeshire vw owners club
