Author Topic: People keep flashing me!  (Read 1862 times)
Offline Fatleg
« on: 30 January 2007, 23:36 »
Can anyone help?
At night I keep getting flashed. Obviously they think I have my full beam on, and I'm sick of flashing back saying, "No I don't! See!".
Anyway, is there an easy way to check/adjust the alignment of my head lights? I bought the car private and I'm assuming the the lamps are of the correct spec.
Fatleg
Offline Golf8vGti
Re: People keep flashing me!
« Reply #1 on: 30 January 2007, 23:45 »
The only 100% sure way of getting the height and alignment checked is to take it to a garage where they can do it all properly.
Offline nadlad
  • Building Surveyor MRICS
« Reply #2 on: 30 January 2007, 23:49 »
turn the nob down on the allignment u plonker!!!!!
<<<Big Build Thread>>>
Offline Fatleg
« Reply #3 on: 30 January 2007, 23:50 »
I have had a look and could only see a dial for dash board brightness.
You sure there is one?
Offline arnoldlog1
« Reply #4 on: 31 January 2007, 17:10 »
have you got RHD headlights in?
Offline Fatleg
« Reply #5 on: 31 January 2007, 21:46 »
Not sure. I don't know much about Golf's, any car for that matter. Is a RHD like a accessory kind of light? As far as I can tell they are standard, or are you refering to the lamp itself?
Fatleg
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
« Reply #6 on: 31 January 2007, 22:56 »
RHD= Right Hand Drive...i.e. are you headlights the correct fitment for your vehicle? where they on the car when you bruaght it? :smiley:
Offline Mantamad
« Reply #7 on: 31 January 2007, 23:09 »
If you have the control for headlight height adjustment it will be located alongside the switch for adjusting instrument brightness - looks the same, a wheel that turns.
Black 2002 GT TDi 130
Offline dsl55
« Reply #8 on: 01 February 2007, 13:11 »
Have you got foglights or full beam on all the time?
Offline R32_T
« Reply #9 on: 01 February 2007, 17:24 »
Best thing, put in front of a brick wall, lights on, at night and you will be able to tell if they are aiming too high, then just adjust appropriately.  :wink:
2001 20V Turbo        1997 VR6 Highline
"Granny shifting not double clutching like you should"
