Hi there,
When this light flashes it normally means that there is a fault logged in the engine e.c.u.
Check that all your brake lights work ok, as this will also cause this light to come on. and the brake light switches are always failing on these golfs.
If brake lights are ok, then you will need to get your fault memory read.
Jochen.
