Author Topic: will these fit?  (Read 1068 times)
Offline cannygti
will these fit?
« on: 08 November 2006, 19:31 »
does anybody know if the following size wheels will fit on my 02 gti turbo?
245/45Z R18 -------- ET 22    81/2Jx18H2
bit confused please help!!!
2002 150BHP GTI Turbo
Offline topher
  • Administrator
  • fully functioning
Re: will these fit?
« Reply #1 on: 08 November 2006, 19:37 »
the 22mm offset doesnt seem right, an 8.5 inch wide wheel should have an offset of around 38 otherwise you may get arch rubbing .. also you dont tell us the stud pattern, should be 5x100.
Offline cannygti
Re: will these fit?
« Reply #2 on: 08 November 2006, 20:33 »
ok cheers they are off a bmw 728 but the bloke selling them reckons they will fit all vw's.
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: will these fit?
« Reply #3 on: 10 November 2006, 18:06 »
7 Series E38:  94 to 02;  PCD = 5x120;  Offset = 15 to 25;  Bore = 72.6mm
Golf Mk4:  98 to 03;  PCD = 5x100;  Offset = 30 to 45;  Bore = 57.1 mm
= A big no-no! :wink:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline cannygti
Re: will these fit?
« Reply #4 on: 12 November 2006, 11:41 »
ok mate thanks for the help
