Author Topic: Oil leeks  (Read 874 times)
Offline billybodger
Oil leeks
« on: 10 November 2006, 11:21 »
 Hi i've got a 2lt 16v with a bit (lots :cry: )of an oil leek from coming from the housing on the top of the oil filter and the mounting which goes onto the side of the block. Anyone got any idear how to get this housing off??It seems to be conected to the cooling system  as its got cooling hoses conected to it . Anyone  idears ????
Offline Daz...
Re: Oil leeks
« Reply #1 on: 10 November 2006, 11:38 »
First you need to take the oil filter off - dont forget to drain the oil first tho...sorry if that's a bit obvious, you never know what some people might do!  :rolleyes:
There's a large nut holding the oil cooler in place, undo that and it will come off.
Obviously you will need to disconnect the water hoses from it aswell but that's nice and easy  :smiley:
08.03.10 - 3, maybe 4 weeks, and I want my golf back on the road!
Offline CL10
Re: Oil leeks
« Reply #2 on: 11 November 2006, 11:11 »
had this on mine the other week.
as daz says, filter off, then the 27mm holding nut for the oil cooler, drain the coolant, remove the hoses from the oil cooler, slide it off the centre spline, then there are 3, 6mm allen key bolts that hold the housing to the block.
mine rounded off :rolleyes: so had to get new ones. space can be limited if you have fat fingers like me  :sad:
took me about 40 mins, start to finish  :smiley:
« Last Edit: 11 November 2006, 11:14 by CL10 »
