Author Topic: Auto hold, hill start, ehandbrake release after Clutch Replacement  (Read 33501 times)
Offline Bluest
Anyone use ODBEleven or other tool to sort this?
Got a new clutch in the car and now the hill hold, auto hold and electronic handbrake release are acting up. They basically don't let go of the brakes at the right time as I pull away.
Google AI suggests that's because the new clutch will have a slightly different bite point and the clutch pedal position sensor doesn't know this, so it needs resetting/recalibrating/adapting using a diagnostic tool to do. Does that sound right?
Can anyone give me a steer. I have OBDEleven Pro, but I don't understand much how to use it yet.
Offline rowlers
  • I'm back - MK7 GTI
I did not have to any of that after my clutch was replaced. Is there a sensor on the clutch pedal?
Offline Bluest
Apparently there is something called the clutch pedal position sensor that measures the travel. 0% = not pressed and 100% = fully pressed. I haven't disturbed the sensor or the master cylinder, but wondering if changing other components might affect the reading.
Offline Bluest
I guess the question is, what else could be causing the issue? Having driven the the auto hold sometimes releases fine, but often tries to hold on, sometimes to the point have depres the clutch and set off again to release it.
Offline rowlers
Try searching for Basic settings on the brakes, autohold etc...
Offline joe6
I think there is a setting in vcds abs module to alter the timing of clutch release but not checked it out. Does the slope the car is on affect how the release point operates? Just thinking if this could it be an issue with the sensor that monitors the slope?
Offline Bluest
Thanks guys, I'm not ignoring you! The weather's been a bit crap for messing with the car. Ill hopefully be able get to it over the weekend.
Offline Bluest
OK, I have had chance to have look now. It turns out there were a mass of ABS, TPMS, ACC and steering fault codes stored, I assume from having the battery disconnected for a few days. When I connected the car back up I had to do the old moving the steering from lock to lock trick to get some dash warning lights to go out. I've cleared all the fault codes and normal behaviour has resumed.
Incidentally, I found the ability in OBDEleven to read the live data from the clutch pedal position sensor. Mine reads from about 9% (un-depressed) to about 90% (fully depressed). Google AI suggests that was normal, but who knows? There is also the the option to do a clutch adaptation in the engine module section, but it was marked as unavaialble for me. Maybe that's a DSG thing?...
