Author Topic: Temp sensor  (Read 1086 times)
Offline Parney
Temp sensor
« on: 19 March 2014, 19:18 »
Got my code reader from fleabay only code is 16500 temp sender.After 10 mins careful studying how to get dam plug off I can see its the original. rang a couple of shops copy is a tenner better quality is twenty both have 12 months warranty anybody wish to enlighten me on what the difference is for my engine.cheers
Offline dom
  • Back in a Mk4
Re: Temp sensor
« Reply #1 on: 19 March 2014, 19:22 »
I'd go genuine all the way with temp sensors, I had a cheap one which failed within a few months.
Offline sharki786
  • GOT BOOST??
Re: Temp sensor
« Reply #2 on: 19 March 2014, 20:12 »
Get one from vw or tps
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline northeast_gti-t
  • "1.8T AGU"
Re: Temp sensor
« Reply #3 on: 19 March 2014, 21:23 »
Earlier models had a blue plug/sensor 4 pin iirc later have the green plug/sensor two pin and as dom says best to get an oem one i found mine on ebay and its from poland but was from an oem parts place and took 4 days to arrive and it was only about a tenner all in :afro: also had that code on mine and changed the sensor due to this but also needed a thermostat change to re=scanned mine after fitting both and no code
2000 Mkiv GTi 1.8T AGU
