Author Topic: How to fix an engine misfire  (Read 2226 times)
Offline Davstylee
« on: 21 October 2011, 23:52 »
Hey people
Right after some time, thinking I had a DSG fault as per this thread
http://www.golfgtiforum.co.uk/index.php?topic=206253.msg1915904#msg1915904
it turns out it is a misfire. I am pretty sure it is a misfire because tonight I got the flashing exhaust light, which according to the handbook is a misfire. However I am not 100% sure because I have never had a misfire before, just going by what the handbook says. Anyway I pulled over, turned the engine off, waited 2 seconds and started her up again and the lights not flashing anymore.
I was hoping someone could tell me how to fix a misfire? I have already had the coil packs replaced under warranty.
Any advice would be great thanks.
Mrk V, GTI, 3dr, DSG, heated seats, winter pack, cruise control, rear parking sensors and now thanks to GizzyWizzy and SteveP in the MK6 section a RCD 510. Awesome!
Offline bacillus
Re: How to fix an engine misfire
« Reply #1 on: 22 October 2011, 09:27 »
Get the car vcds scanned to see the stored fault code then go from there.
Without traction power is nothing!
Offline seiko
« Reply #2 on: 22 October 2011, 20:19 »
did you have the spark plugs changed the same time as the coil packs? and vcds is the best option as the previouse post
Offline MaXXeH
  • Golf MK5 GTI
« Reply #3 on: 22 October 2011, 20:19 »
mine has blowen the coil packs that at 4 months old.   Does not matter if they are new.  could also be spark plugs
