Author Topic: Replacing Clutch  (Read 1175 times)
Offline rcsammy
Replacing Clutch
« on: 15 May 2011, 23:19 »
I think the clutch might need replacing on my mk3, the pedal is stiff, bite point is fairly high and it is slipping  a bit.
its a 1992 1.4
Im pretty confident working on my own car but i know clutch's can be a pita, so how hard of a job is it and is there any special tools required?
Re: Replacing Clutch
« Reply #1 on: 15 May 2011, 23:23 »
Not that easy to do but on the other hand if you know your way around you should be able to sort it.
Offline rcsammy
« Reply #2 on: 16 May 2011, 00:40 »
Need to pick myself up a Haynes manual or somthing similar
If it doesnt require the engine to be removed or any special tools then i should be able to do it myself
Offline Dan_GTi8v
« Reply #3 on: 16 May 2011, 01:05 »
You may need an odd sized spline socket to undo the bolts. Think its something like m7 11/32 spline, not all of them have it though some use normal bolts
Offline rcsammy
« Reply #4 on: 16 May 2011, 21:11 »
Cheers, are they the bolts on the clutch itself?
