Author Topic: front seats  (Read 1651 times)
Offline adams mk2
front seats
« on: 05 March 2011, 00:10 »
how do you remove the front seats?
Offline The Mighty Elvi
  • I'm better than you today.
Re: front seats
« Reply #1 on: 05 March 2011, 09:52 »
Under the front of the seat you will find a bracket that holds the seat frame onto the guide rail.
Undo the bolt on the bracket and the seat will slide out..
Offline Thom89
  • Looking for an "Icebreaker"
Re: front seats
« Reply #2 on: 05 March 2011, 13:39 »
As above, but clear out the runner channels, and give a shot of WD40 prior to removing the seat, any debris in them can cause them to jam up, and be a pig to remove, you'll also notice a nice difference when the seat is re installed, and it adjusts freely..
Thom
Offline HARVS1789UK
Re: front seats
« Reply #3 on: 06 March 2011, 09:53 »
- remove plastic cap/end piece from the back of the seat runners by wiggeling it off (down in the foot well of the rear seats)
- using a flathead screwdriver or similar prise out the little plastic pin which holds the runner trim on (this is a total b!tch and if you can do it without scratching little chunks out from around it your a king) its a little black circle which is camouflaged in with the seat runner trim.
- at the front centre of the underside of the seat there is a bolt. one side is your standard hexagonal bolt head the other required an allen key. undo it and take it out
- pull up the arm which lets you slide the chair forward and backwards. Go backwards and keep on going and it will slide out of the runners.
-lift it out
HARVS
