Author Topic: New Turbo..New oil feed line?  (Read 1125 times)
Offline EuanGtTdi
« on: 17 December 2010, 19:58 »
Hey
right so my turbo went on my vrs massively amount of play on the shaft
is it a good idea to change the turbo oil feed at the same time?
also would the garage (prime) i think it is the turbo before start it up or something?
Euan
Offline flamotronic
Re: New Turbo..New oil feed line?
« Reply #1 on: 20 December 2010, 22:10 »
Yes, a new oil feed pipe is recommended: it is logical to do so because a new oil pipe means clean, uncontaminated oil entering your new turbo for the first time!
You should be able to pick one from the dealers for around £25 inc VAT.
The mechanic fitting your turbo should prime it, as per the usual instructions of your turbo supplier.
PQ34 Wolfsburg Type 1J Turbo-direct Injection Pumpe Duse 115
A work-horse of a vehicle; this and that going wrong, but it's still a Dub, 'aint it?!
