Author Topic: Engine code  (Read 1720 times)
Offline jonesltd
  • MK7 R
Engine code
« on: 18 August 2009, 17:38 »
M8 has a W reg 2000 gt tdi golf and needs to know what the engine code is to replace the starter motor as the part number has been wiped! I believe its a 115bhp certainly not anything lower as it keeps up with my 130 pretty well. I am engine code ASZ being 130
If you cant find it......Grind it
Offline Mr_Orange
Re: Engine code
« Reply #1 on: 18 August 2009, 17:52 »
Can you get a look at the engine?  Code is stamped on top front corner of the block.
Build thread clicky
Offline Rhyso
Re: Engine code
« Reply #2 on: 18 August 2009, 19:10 »
AJM if its a 115bhp
Offline richw911
Re: Engine code
« Reply #3 on: 18 August 2009, 19:15 »
Offline jonesltd
  • MK7 R
Re: Engine code
« Reply #4 on: 18 August 2009, 21:40 »
If it is a 115bhp can I still use a 130bhp starter motor?
Just checked it said on the side of the connected to the block under the TDI cover AJM 186 464
« Last Edit: 18 August 2009, 21:46 by jonesltd »
Offline jonesltd
  • MK7 R
Re: Engine code
« Reply #5 on: 18 August 2009, 22:01 »
VW dealers said they recommend this for the starter motor but as its old it wont be factory fitted? 02m911023F and most I see for the 1999-2000 models ends with an A? Does that matter and will it fit if I got the A?
Offline snap-on
Re: Engine code
« Reply #6 on: 18 August 2009, 23:08 »
engine code is also on the big white sticker which is in the boot stuck to the floor under the carpet which also has tons of other info on it
Offline richw911
Re: Engine code
« Reply #7 on: 18 August 2009, 23:11 »
Which is in the link i posted ^^^^  :wink:
Offline jonesltd
  • MK7 R
Re: Engine code
« Reply #8 on: 19 August 2009, 12:43 »
yep looked at that but can the AJM 115 model have a ASZ 130 model starter motor put in it?
