Author Topic: What bulbs do I need for Hella Quads?  (Read 5741 times)
Offline BA005
« on: 05 June 2009, 12:06 »
I've just purchased some Hella Quad headlights for my mk3 from an internet auction.
But the seller suggested that I replace the bulbs. I'm not sure if it's because they're broken, or just a bit old.
Does anyone know what type of bulbs I need? And there are 4 I presume? Are all 4 the same type?
Roughly how much will the bulbs cost me?
Many thanks
Offline VR6-Joe
Re: What bulbs do I need for Hella Quads?
« Reply #1 on: 05 June 2009, 12:10 »
Outer lamps are H1's
Inner lamps I think are H3's the same as the front fog lights
Sidelight bulbs are 233's
Get them off ebay and probably won't cost you much more than 10-15 quid, depending on which ones you buy..
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
« Reply #2 on: 05 June 2009, 12:11 »
You should have most of the bulbs in your old headlamps.
Offline VR6-Joe
« Reply #3 on: 05 June 2009, 12:14 »
Depends really mate,
GTI/VR6 headlamps had 2x H1 bulbs per light, and depending on age, either 501 or 233 sidelight bulbs
CL headlamps had 1x H4 bulb per light, and once again depending on age, either 501 or 233 sidelight bulbs
So technically speaking, if he's putting the headlights onto a CL spec car, then there's a possibility he hasn't got any of the bulbs lol
Offline BA005
« Reply #4 on: 05 June 2009, 12:16 »
Thanks very much for that indeed.
So I need a pair of H1's and a pair of H3's, right?
What do you mean by sidelights?
Offline VR6-Joe
« Reply #5 on: 05 June 2009, 12:24 »
Yes mate, H1's and H3's. But if you're removing GTI/VR6 dual chamber headlamps from your car, they'll have H1's in them, so that could save you a few pennies.
Sidelight bulbs.. the bulbs that come on when you turn your sidelights on? These are the ones I was using.. Sidelight bulbs
Although I'd wait to see what you get with the headlights before you waste any money :smiley:
Offline BA005
« Reply #6 on: 05 June 2009, 12:34 »
You're very helpful VR6-Joe, thanks.
My Hella Quads are arriving tomorrow, so I will check what's what. If I need your help again tomorrow, will you be around?
« Reply #7 on: 05 June 2009, 12:36 »
Good point, did not think of that.
Offline BA005
« Reply #8 on: 05 June 2009, 12:40 »
I'm putting the Hella Quads onto a vr6. So since I am removing factory spec headlights, I will already have the correct bulbs, no?
Offline VR6-Joe
« Reply #9 on: 05 June 2009, 12:58 »
Yep I'm always lurking on this site, gets pretty addictive haha.. if you need any help just ask..
As you're removing stock VR6 headlamps, you'll be able to remove the H1 bulbs from them, and use them in the outer Hella lamps, which means you could possibly only need a pair of H3's and a pair of 233 sidelight bulbs, but like I say, it depends what the lights come with.. they might come with fully working bulbs, sounds like the seller may have had them stored for a while and doesn't know if the bulbs still work etc
