Right after fitting the THS cooler I only hit 14psi peak on a 3rd gear run and there is a definite lack of power so I'm in need of a boost leak test.
What I need is a definitive answer on how to leak test on the engine, bearing in mind I have a catch can fitted. I've got an attachment for a paint gun which can regulate air from the compressors at work and I can get a nylon bush turned to plug the TIP.
Do I need a valve to hold the pressure etc? Any help would be much appreciated
I just turned a nylon bush up, drilled and tapped to accept a 1/4bsp needle valve with some compressor fittings, will post some pics if this will help.
As far as a definitive guide goes, I think it would be a good Idea to start a thread all about pressure testing and results as I get a small amount of leakage through the block but with nothing to compare it to, I dont know if I need to look into things further or if I am wasting my time.
I also get a bubbling in the sump when I test from the tip, which I am sure you must be able to stop.
Firstly though, I need a more aggressive map!
