Author Topic: Battery replacement  (Read 4062 times)
Offline itavaltalainen
Re: Battery replacement
« Reply #20 on: 18 March 2021, 17:39 »
You need pro to code in a battery in adapations.
You can pick up a NextGen with Pro on Amazon for about £70
Offline Lordie
« Reply #21 on: 18 March 2021, 19:59 »
What's the difference between the regular and the pro?. It's difficult to find out online a solid list as to what each does. I know the pro does long coding but is that just for professionals to mess with?
If I got one the things I know I'd want to do is - Code new batteries myself, try Audi throttle response, turn off fake engine sounds etc
« Last Edit: 18 March 2021, 20:02 by Lordie »
Offline Finglonga
« Reply #22 on: 19 March 2021, 09:27 »
Tells you on their site what advantages the Pro has https://obdeleven.com/en/nextgen
Worth getting the pro as it does much more, the next gen is considerably quicker as well.
Offline GTi Andy
« Reply #23 on: 06 April 2021, 10:39 »
Can I ask why a battery will need coding please?
I got caught out with a flat battery recently and had no option but to go to Halfords. One of their guys fitted it for me as I was in a rush, he never coded it.
Offline sjw
« Reply #24 on: 06 April 2021, 13:44 »
No you don't
Offline sjw
« Reply #25 on: 06 April 2021, 13:45 »
It lets the car know what it should be charging to, that it should adapt the charging rate, etc
Offline golfdave
« Reply #26 on: 06 April 2021, 21:23 »
I di a how to guide way back in 2015 which I've just been tiding up to the newer formatting...all info in first post..
https://www.golfmk7.com/forums/index.php?threads/how-to-retro-fit-a-bigger-capacity-battery-to-a-mk7-golf.320084/
