Author Topic: Realistic thoughts about AGU stage 2  (Read 24366 times)
Offline DunnDeal12
  • Limited
Re: Realistic thoughts about AGU stage 2
« Reply #20 on: 05 July 2012, 22:43 »
be lucky to see over 225bhp without a actuator.
ive seen a few agu ko3s that have made it past 230bhp without forge actuator.
Offline golfyste
  • Project track car
« Reply #21 on: 05 July 2012, 22:46 »
Yeah but it wont last long! the standard actuators would soon go weak and then they will be loosing power.
You can make good power with a healthy standard actuator but it will soon die!  :laugh:
Offline rio_gti
« Reply #22 on: 05 July 2012, 23:12 »
I would be happy with about 240bhp as im not chasing big power, Ideally I am wanting power so a nice torque line is what im looking for anything over 270lbs would be cool.
Looks like im on a hunt for a Fmic then  :smiley:
Bloody expensive things though haha
That's why I'm to replicate the ths one but on the cheap..... Just waitin for some measurements then will write a list and cost of what's needed  :wink:
Offline Scott D
« Reply #23 on: 05 July 2012, 23:14 »
was getting 192g/s with the k03s on standard actuator, mind you it had a very easy life and only 52k  :grin:
230bhp+ is possible with SMIC although heat soak is bit of an issue and probably would get more torque with a front mount.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline shaft69
« Reply #24 on: 05 July 2012, 23:34 »
Never got any heat soak with my smic on rollers with side mount got to be with size, quality and venting of the unit???? With smic arch MUST be vented properly.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline DunnDeal12
  • Limited
« Reply #25 on: 05 July 2012, 23:35 »
mines doing fine and its been on the car 2yrs. previous owner fitted brand new KKK turbo and had it remaped by R-tech.
i brought a forge actuator and took the car down to rtech hoping they would fit it but after looking at it and having it on the rollers he said the oem one was fine.
Offline shaft69
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline golfyste
  • Project track car
« Reply #27 on: 05 July 2012, 23:54 »
What power are you pushing?
I would still personally get one as then you know you won't be loosing boost
Offline Scott D
« Reply #28 on: 06 July 2012, 00:06 »
Did have a standard SMIC with no other mods than a THS pancake replacement pipe which probably is why after ragging it felt down on power  :grin:
looks fk'in huge for an side mount that Tyrol Sport and no doubt less laggy than a front mount, how tight of a fit is it?
Offline shaft69
« Reply #29 on: 06 July 2012, 00:23 »
Need to cut out some of trim behind headlamp other than than straight fit, sits a lot lower than standard one being a lot longer. Will give you power output in 2weeks when all is fitted, finished and rollered.  :grin:
184 Wallgate, Wigan
WN3 4AL
07966492823.
