Author Topic: Armour Door Plates Removed - Shouldn't be surprised!  (Read 1922 times)
Offline barkstar
Re: Armour Door Plates Removed - Shouldn't be surprised!
« Reply #10 on: 14 December 2008, 23:33 »
The right dolly and a panel hammer should do the trick but best be in the hands of a time served panel beater.:wink:
Barkstar
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #11 on: 15 December 2008, 00:08 »
As above, flat dolly pushed hard into the dent from inside the door, then gently tapped with a polished planishing hammer from the front, dont over do it as the metal will start to stretch.. DONT do it with any type of grip or pliers, you will make the dent bigger, and damage more of the paint
Those door plates are a complete waste of time, someone has broken into your car, and only made a small dent and easily repaired, Ive repaired doors that have had the plates fitted, and the doors have been butchered beyond belief.. the first thing I did when I got my Golf was to get shot of them!  the only real use they have is to hide expensive damage on a car that doesn't warrant a proper repair...
Tom
« Last Edit: 15 December 2008, 00:11 by thom89 »
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #12 on: 15 December 2008, 02:45 »
Barkstar
What he says. You need to re-shrink the damage as the metal will have stretched a little. But looking at the damage, most of it woll be hidden by the handle gasget.
Offline drapergti
« Reply #13 on: 15 December 2008, 11:00 »
Cleary on for the professional any takers in Kent? Not something I would want to screw up and then ask someone to repair at even greater expense!
