Author Topic: khare's mk3 GTI...16v!  (Read 246455 times)
Offline davero
Re: khare's mk3 GTI 8v
« Reply #200 on: 16 May 2009, 00:55 »
Lowering springs ruin mk3's handling very quickly, your shocks are probably shagged.
Offline Khare
  • The bear that khares
« Reply #201 on: 16 May 2009, 00:57 »
Dont know bout shocks but i know the springs are. Diamond hell had a look at them when the front was polybushed and he said they were <insert proper word here> touching together, basically they were fooked.
Offline davero
« Reply #202 on: 16 May 2009, 01:02 »
If you put a decent set of shocks/springs on or coilovers, I gaurantee it would feel like a new car.
My personal preference is shocks and springs(koni/Eibach), for both ride and handling.
The only downside is looks
« Reply #203 on: 16 May 2009, 09:17 »
Mk3 were underdamped from new so if your running lowering springs then it will not help the handling, mine was loads better on coilovers.
Offline Khare
« Reply #204 on: 16 May 2009, 11:05 »
i know coilovers will make it feel like new, hence me buying them (and partly lowering)
But you cant compare cars taht have the same suspension near enough but one weighs 900kilos and the other over a ton.
Offline Dec
« Reply #205 on: 16 May 2009, 11:10 »
There is 250kg between a mk2 and mk3 i believe.
Offline Khare
« Reply #206 on: 16 May 2009, 11:12 »
thought mk3 was 1050kg  :huh:
Offline Dec
« Reply #207 on: 16 May 2009, 11:32 »
Nope, the mk3 is 1285 kg and the mk2 is 1050 kg I think.
Offline Khare
« Reply #208 on: 16 May 2009, 11:38 »
i swear i read on here mk3 is 940kg and mk3 is 1050kg.
Offline Adam
« Reply #209 on: 16 May 2009, 12:11 »
Yea, your right. Im sure that was on someone's signature...."Slimfast" was it sharpies?
Down Hill From Here.
