Author Topic: khare's mk3 GTI...16v!  (Read 246443 times)
Offline Khare
  • The bear that khares
Re: khare's mk3 GTI 8v - UPDATE
« Reply #110 on: 30 April 2009, 20:59 »
another pic of it. Shows it more clear.
Offline Khare
Re: khare's mk3 GTI 8v - US Spec indicators
« Reply #111 on: 02 May 2009, 19:14 »
Today i fixed drivers saggy door, thanks to reading up an old thread here about sticking a wheel nut in the door hinge and closing the door, and also, fixed electric sunrood and ABS and airbag lights. Fuse kept blowing at first, and today i found a fuse in my toolbox so i tempted luck, and when i turned ignition it didnt blow, so tried sunroof and it worked!  :cool: just in time for summer too!
On the downside, when i went to adjust door striker i came across two very rounded bolts, so need to somehow remove them rounded bolts and get some new ones from the scrap yard.
Offline Khare
« Reply #112 on: 03 May 2009, 15:20 »
Golf 3
To do:
•   Rear number plate light
•   Locking wheels nuts
•   Adjust drivers door
•   Clean throttle body
•   Drill air box
•   Full wet-vac clean inside
•   Full outside clean, wax and polish
•   Replace bumper air vents with cold air intakes
•   Fix outside air temperature sensor on MFA
•   Replace: Spark plugs
                 Oil and oil filter
                 Distributor cap and rotor
                 Air filter
                 HT leads
•   Improve aerial
•   Fix sunroof
•   Fit new speakers
•   Fix tire pressures
•   Red GTI front badge
•   VR6 front splitter
•   Wire hazard lights to alarm
•   Fix 3rd brake light
•   Buy and fit hella quads
•   Align hella lamps
•   Spray VW badge black
•   Fix windscreen washer bottle
•   Fit poly bushes, new ball joints and new top mounts
•   4 wheel alignment
•   Fix water leak from the front head connector
•   Install chip
•   Install new steering rack
•   New gearbox mount
•   Gearbox oil service
Extras
•   Paint brake calipers
•   Polish valve cover
•   Touch up scratches
•   De-cat
•   Coilovers
My to do list. Nearly all done.
Offline Khare
« Reply #113 on: 05 May 2009, 22:46 »
trip to scrappy today and i bought boot struts, new mirror cover to replace my broken one, and another cam cover, to spend time on it polishing it up nicely.
Offline Shady Pioneer
  • graphic designer.
« Reply #114 on: 05 May 2009, 23:01 »
Did my guide help?  :kiss:
Offline Khare
« Reply #115 on: 05 May 2009, 23:02 »
not but the phone call did  :grin:
  • graphic designer.
« Reply #116 on: 05 May 2009, 23:04 »
:grin: :grin: :grin: Same thing really :P looks good my man :)
Offline Khare
« Reply #117 on: 05 May 2009, 23:05 »
cheers dude. Now i can show my rudder and keel under the bonnet  :grin:
Offline dublove
« Reply #118 on: 05 May 2009, 23:28 »
Looking good dude, same colour as mines. colours mystic blue but look more of a metalic purple to me.
Offline Khare
« Reply #119 on: 05 May 2009, 23:32 »
yeah my mates always say to me "mate you're car is purple" and im like "No, for the 100th time, its mystical blue!"  :grin:
