Author Topic: Can't figure out how to replace the Jack! (blush)  (Read 3683 times)
Offline stealthwolf
Re: Can't figure out how to replace the Jack! (blush)
« Reply #10 on: 12 December 2008, 16:42 »
okay so I had a look. Took the jack out, opening it up a bit and closed it and put it back without problems.
1. Close the jack fully until you get resistance on the handle (doesn't need to be too tight or you'll have difficulty opening it next time).
2. Rotate the jack as needed so that the screw is facing you (ie you can see the whole length of the screw) and the white bit is closest to you and the flat angle furthest from you.
3. The handle folds to the left of the jack as you look at it. You may need to tighten/loosen the jack accordingly.
4. Now the jack is compact, hold the jack so that long part of the screw is facing the right side of the boot (where there's a little pocket in the boot) and then rotate 90 degrees so the long screw is now facing you.
5. Put the jack into its slot. The handle should be touching the bottom of the slot. The angle should be to the right. The long screw should be facing the seats.
Diagrams to follow (i forgot to take my phone with me)
« Last Edit: 12 December 2008, 16:46 by stealthwolf »
Offline stealthwolf
« Reply #11 on: 12 December 2008, 16:54 »
Can't believe instead of revising, I'm telling someone how to put the jack back.
Okay, the first figure shows how the jack looks as you hold it in your hand. The screw part should face you and the handle on the left.
The second figure shows how the jack should look once it's in place. Ignore the angle (I can't remember whether it faces up or down but you should be able to match it with the slot).
If it won't slide easily into it's slot, you might not have closed the jack fully. Retry.
WhiteGTI
« Reply #12 on: 12 December 2008, 17:25 »
I can't believe that instead of revising, I am looking at instructions on how to put the jack back, when it turns out that mine is actually in there correctly!  :smiley: :smiley:
Finance exam on Tuesday  :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry:
Offline No Golf Clubs at all
« Reply #13 on: 12 December 2008, 18:20 »
 :laugh: :laugh: :laugh:
Classic avoidance??
Will try this and report back asap, any one got  a pic? I have a feeling the jack may end up going through the window of my neighbours house    :tongue:  thanks all anyway, much appreciated!
Let the fun begin........Red Gti, full colour coding, DSG, Xenons, Winter pack, Lux pack, Highline, Sat Nav, Sunroof, Leather, Milltek, ABT rear valance, Goodyear F1 Asymmetrics....pescaras :-)
Offline stealthwolf
« Reply #14 on: 12 December 2008, 18:52 »
Will post a pic tomorrow in the daylight when I put the alloy nut covers back on.
Offline Gene Hunt.
« Reply #15 on: 12 December 2008, 19:24 »
BBS LM replicas. Heres a closer pic
..........as above sorry to spam the thread but are these the ones off ebay ? & how are they standing up to the winter so far by the way they look  :cool: :drool:?.Cheeers Steve.
Candy White ED35.
Offline stealthwolf
« Reply #16 on: 12 December 2008, 20:27 »
I love those alloys - they work fantastically with silver GTI. Dunno how they'd look on black.
Offline stealthwolf
« Reply #17 on: 12 December 2008, 20:28 »
Komenda, just noticed, what's the blue bit on the headlight towards the grille?
WhiteGTI
« Reply #18 on: 12 December 2008, 20:54 »
Hasnt Joesgti got similar wheels? That may give you an idea..
Offline Komenda
« Reply #19 on: 13 December 2008, 11:47 »
Joe has BBS GT on his car and they look the muts so I reckon LM's will work. Pictures don't always give a true representation. Quite like the matt black though.
That blue tint is the Diadem indicator bulbs, appear a bluey silver colour when off but flash orange.
