Author Topic: Exhaust Pop  (Read 2891 times)
golfvr6
Re:Exhaust Pop
« Reply #10 on: 15 June 2004, 08:22 »
Veedub,
get under the car and check the exhaust joins, it still sounds like you may have a small leak.
sometimes the actual join bits knacker and won't tighten up properly so don't seal.
does that make sense?  ???
Fielder5757
Re:Exhaust Pop
« Reply #11 on: 15 June 2004, 09:37 »
Also, It could be worth just taking your exhaust appart, Theres a small but that overlaps where the exhaust meets, This can some times rust as well and cause tiny leaks. Always worth a check on a stock exhaust system. ;)
Offline ANSA
Re:Exhaust Pop
« Reply #12 on: 05 July 2004, 09:46 »
I am having the same problem on mine but when it does pop i have a huge power loss like the car isnt getting no petrol,, The wierd thing is when the car is cold it drives fine and no pops or power loss but when the engine is warmer it starts,, nasty though as i nearly had a massive truck plaugh into me whne taking  off on a round about the damn thing started poping and cut out on me,,,, Any ideas why this could be guys.. ??? :'(
