Golf mk2
rear wheel bearing change
Topic: rear wheel bearing change (Read 9601 times)
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: rear wheel bearing change
Reply #10 on:
10 December 2008, 13:42 »
you need to tighten it past hand tight whilst spinning the disc/drum at first to settle the bearing then back off and set hand tight. By past hand tight, I dont mean lean on it with a breaker bar, just enough for the nut to become tight. If you want an exact figure its given in the bentley:
http://www.iol.ie/~kilkennyhockey/BentleyManual/SU01/ch6.2.2.html
paultownsend
Reply #11 on:
11 December 2008, 00:56 »
excellent, as i did when i put the last set of disks on
Golf mk2
