Author Topic: FK coilovers  (Read 3354 times)
sharpie
Re: FK coilovers
« Reply #20 on: 09 December 2008, 12:59 »
I'm sure you can buy FK's to fit your mk2 from anywhere for £350 mate :smiley:
aye FK highsports maybe but not konigsports.
i had highsports off a mk3 vr6, they were ok really but never had them long enough to test them thoroughly.
Offline danny_p
Re: FK coilovers
« Reply #21 on: 09 December 2008, 13:15 »
FK are far,far superior to Hot tuning etc.
They are designed for motorsport and for that reason along they excel the others.
they ain't desinged for motorsport.  the koingsports are ok  but the likes of KW v2 and v3 are the start of the motorsport stuff
all the VW's have gone bar 1.
Offline paultownsend
Re: FK coilovers
« Reply #22 on: 09 December 2008, 13:23 »
has anyone seen these? look like a quality item
http://www.edition38.com/forums/index.php?showtopic=190842
Offline Organisys
  • Old and Slow...
Re: FK coilovers
« Reply #23 on: 09 December 2008, 18:41 »
Interesting but new to the market I guess. If you can stretch to £500 I would go for Weitec.
Very please with mine.
Stainless threads, Height easily adjusted. Mine been on over a year, no seizing.
Good damping adjustment too.
Offline Ben Lessani
Re: FK coilovers
« Reply #24 on: 09 December 2008, 20:11 »
What is this obsession over wanting to adjust the ride height on a road car?
You'll put 'em on, adjust them to the height you want, then you'll leave 'em for 6 months or more and they'll seize solid.  Just fit some appropriate quality struts, with some -40mm lowering springs and be done with it.  They're much less likely to go wrong and won't die in a year or so.
Aint that the truth! Well, except the siezy bit - as long as when you fit them you apply ludicrous amounts of copper slip/chain wax they tend to still be pretty adjustable months down the line. The thing is, why would you keep changing your ride height - its just going to do peculiar things to your camber/tracking.
Offline Goops
  • mk2 gti 16v
Re: FK coilovers
« Reply #25 on: 10 December 2008, 00:18 »
I read about the coilies seizing up esp in the sh**tty weather so greased the fk konigsports and am wearing these "socks":
Il let you know if they seize when i change the winter wheels  :smiley:
I guess the ride height adjust is useful if you change wheels often (diff profiles etc) and is quite handy for changing the stance etc
More for cosmetic reasons i suppose! (Until you break the front splitter)  :grin:
Re: FK coilovers
« Reply #26 on: 10 December 2008, 00:18 »
here here
weitec fixed rate kit -40
matched damping to spring rate. perfect
i found eibach to be too soft as progressively wound.matched with boge turbo shocks
