Author Topic: problematic air filter  (Read 1305 times)
Offline player.777
« on: 30 November 2008, 20:36 »
having only had my pipercross in for about a week.  i am sure the economy is less by about 10% than it was before.  In fact, I just did over 200 miles on the motorway and ended up with 49.1 mpg.  not as good as usual on the motorway thats for sure.  Now my question is this- i presume now there's more air going in, more fuel is needed for the fuel- air mix. so will the ECU manage to change this back to normal after a while, or will it stay like this??
Because I'm having the re-map done next wkend should I swap back to original filter now so the re-map is done on a completely standard set-up???  will it make any difference?
Offline Rhyso
Re: problematic air filter
« Reply #1 on: 30 November 2008, 21:18 »
whats your outside temp gauge showing??
you'll find that diesels do take a slight hit in economy due to the colder weather
Offline player.777
« Reply #2 on: 30 November 2008, 21:44 »
this afternoon it only got down to 4.5 degrees once.  its been colder and has never been effected like this.
Offline oliver07
  • golf gti T 200BHP
« Reply #3 on: 01 December 2008, 15:43 »
is it a panel filter as these dont use any more fuel but the aftermarket external ones seem to :grin:
Offline player.777
« Reply #4 on: 01 December 2008, 20:04 »
yes its a panel filter. put the original manufacturer one back in today to see if it would make any difference and I'm sure it did- maybe I'm just going mad!!  Are you sure pipercross panel filters don't use any more fuel??  How come?? surely with more air going in, more fuel is needed to balance the air-to-fuel mix?? Or is it the other way round- more air in, less fuel is needed???
Offline oliver07
  • golf gti T 200BHP
« Reply #5 on: 01 December 2008, 20:07 »
well the boys on here told me same fuel use but better breathing for the engine sorry buddy thats all I know :wink:
Offline ben1.8T
« Reply #6 on: 02 December 2008, 08:33 »
My fuel consumptions about the same with mine fitted and I have also got the Forge TIP fitted.  :smiley:
Golf SOLD. Replaced with a Yamaha Raptor 660 quad and loving it. This will be replaced in August with a Raptor 700. Sold the quad now got a Vectra GSI 2.5 V6 and its the nuts.
Brands Hatch massive. MEMBERSHIP ACCEPTED!
Offline player.777
« Reply #7 on: 02 December 2008, 09:07 »
Ok thanks, don't really know why the consumption is inceased so much then.  thanks for your help
