Author Topic: fitting porsche wheels 108 pcd  (Read 2362 times)
Offline rat-look
« on: 28 November 2008, 17:25 »
want to fit some porsche wheels to my mk2 but the pcd is 108, are there any disks available that have a 108 pcd?
Offline Mr Blue
Re: fitting porsche wheels 108 pcd
« Reply #1 on: 28 November 2008, 17:30 »
108pcd on a porsche? what wheels are they then?
4 stud/ 5 stud?
Im sure 108 pcd didnt come on porsche. More like pugs and citroens
Hub adaptors are what you want. example...
http://cgi.ebay.co.uk/VW-2-Porsche-Wheel-Hub-adaptor-4x100-5x130-Hubcentric_W0QQitemZ290278813225QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item290278813225&_trksid=p3286.c0.m14&_trkparms=72%3A1301%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
You can have them filled and re-drilled to 4x100. Easier and cheaper. Your local engineer can do this
You can have the hubs redrilled also but not worth the hassle
« Last Edit: 28 November 2008, 17:35 by Mr Blue »
Offline rat-look
« Reply #2 on: 28 November 2008, 17:36 »
early porshche 4 stud
Offline filthy
« Reply #3 on: 08 December 2008, 20:32 »
Porsche 924...the other early 4 stud porsche (the 914) was the same as a beetle...4x130
Audi 80s were 4x108, try the discs off one of those
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
Offline Mew
« Reply #4 on: 08 December 2008, 20:52 »
Erm, you do realise the wheel nuts go through the disc, not into it, right? On the front that is.
rubberdubber
« Reply #5 on: 09 December 2008, 07:56 »
yes the wheel bolts go through the disc and thread into the hub, so dont waste your money on any discs!  :wink:
Offline danny_p
« Reply #6 on: 09 December 2008, 13:22 »
chould proably fit audi hubs into vw hub carriers then ause audi brake disk
all the VW's have gone bar 1.
Offline Mr Blue
« Reply #7 on: 09 December 2008, 18:20 »
Wobble bolts ? Might get away with these.
Have them redrilled?
« Reply #8 on: 10 December 2008, 09:02 »
Wobble bolts only allow a max of 2mm difference ie 4x98 to 4x100, you may be able to get audi discs to fit or have them welded up and redrilled.
