yeah that sounds like you have a wiring fault to the coil and/or dizzy... I do indeed have a 16v, unfortunatly I'm busy this weekend though
I'd start by poping off the plug to the ignition controller and TCI thingy under the plastic cover at the very top of the engine bay, driver side. make sure the pins on these are free of any corrosion. then look at the coil which is the round thing where the middle spark plug wire from the distributor goes to, check all the wires here are in good nick. Then look at all the wiring to the side/rear of the head itself, look at any earth cables brown or brown white, and check any sensor wires for damage.
