Author Topic: Help with a disconnected connector on Throttle body (pic)  (Read 1820 times)
Offline Canters
Re: Help with a disconnected connector on Throttle body (pic)
« Reply #10 on: 31 January 2009, 21:43 »
Hi All,
Thought I would post the fix to this issue. This might not be the fix for all with the same problem but might help some one. :)
I got fed up with having to "play" the car on cold mornings and getting caught a junctions. So I took it the garage around the corner and told them the issue and about the connector. Left it with them and an hour later got a call to say it was ready for collection.
They connected the connector and connected the car to the PC, then reset the throttle limits and took it for a test drive.
It's been running like a dream since and drinking less fuel. :) Not bad for £40.
Hope this helps someone else and thanks to all for the help and advice.
Canters.
Offline harlemex
« Reply #11 on: 01 February 2009, 14:14 »
Excellent bit of advice Canters. Thanx for posting it. :smiley:
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #12 on: 02 February 2009, 14:35 »
Thats an AE series engine..1.4 or 1.6,  That connector is the main feed for any sensors and throttle position control built into the throttle body,  When i unpluged mine, the engine would die, so mabey the ECU has learnt how to work arround it,  so disconnect the battery plug the connector in and see how it goes  :smiley:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
