Author Topic: Digifant to Kjet  (Read 1926 times)
Offline Diamond Hell
  • Opinions я Us
Re: Digifant to Kjet
« Reply #10 on: 24 November 2008, 19:46 »
Where are you?
Offline dubstar81
« Reply #11 on: 30 November 2008, 18:14 »
I'm down in Plymouth.
I have been doing some research and i found out that the digifant runs a higher pressure than the K jet and the K jet has a sort of booster pump within the tank to prime the fuel pump, so what i have found done is found one, And also i managed to come across a complete k jet wiring loom.
The plan is if the pump doesn't sort out the priming problem i am going to rip out the old crappy loom and replace it with a proper one.
Offline danny_p
« Reply #12 on: 30 November 2008, 18:19 »
k jet runs higher pressure than digi,      both systems have 2 pumps,  the intank pump is same for both  the under car pump is diffrent
all the VW's have gone bar 1.
