Author Topic: ALL MK 2 OWNERS TAKE NOTE!!  (Read 37520 times)
Offline 6foot6
Re: ALL MK 2 OWNERS TAKE NOTE!!
« Reply #60 on: 21 December 2009, 16:57 »
Change your bypass valve luv and you'll be fine.
Where is thisin the bay or under the dash? any pics?
My heaters are crap also!
Golf GTi 8v Alpine white - Project track shlag - TLC needed - KnN/Scorpien full system oval tail pipe, rust here and there.
1991 Toyota MR2 MK Revision 1 Turbo, rev 3 LSD, CT20b Turbo, HKS Exhaust, Blitz Downpipe 244HP@the wheels @ 13psi - 12.9 SQM :D
1994 BMW 730 V8 fully loaded 220BHP
Offline Alec
« Reply #61 on: 21 December 2009, 17:03 »
follow the heater hose out the side of the engine on the right hand side as you are looking under the bonnet. Just before it goes through the bulkhead there is a metal valve on the hose. I took a pic of mine to send to the vw dealer the other day, when I can be bothered I will get it off my phone and on to photobucket for you
Offline 6foot6
« Reply #62 on: 21 December 2009, 17:09 »
I know the pipe, cool, is there a way of knowing it goosed , all the coolant pipes there are burning hot!
Offline Alec
« Reply #63 on: 21 December 2009, 17:37 »
Check if the pipes going through the bulkhead are hot. There are two pipes, one feed and one return (I think). At the bypass valve mine has a smaller and thinner hose that bridges the feed and return at the valve if that makes sense. I'll plug me phone in shortly so you can see mine.
My heaters are duff also  :smiley:
Offline Alec
« Reply #64 on: 21 December 2009, 18:05 »
Hope that helps
Offline leeroy20vt
  • h reg mk2 gti
« Reply #65 on: 21 December 2009, 18:41 »
well my heater is pants to just changed these valves off a working car i knew heater was good still no heat in my car the pipes are red hot either side of valves and theres deffo water passing thru heater matrix
so do i just swap matrix or is there something im missing
Offline Alec
« Reply #66 on: 21 December 2009, 19:29 »
Think theres a flap inside the dash that blocks off the hot air isnt there, maybe this is closed off? Might be best asking Horney or Diamond Hell though, they seem to live and breathe old golf stuff man.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #67 on: 21 December 2009, 19:51 »
i had thought about that but i get hot air for about 10 seconds of turning the blowers on then stone cold
also u forgot mr jonny on that list lol all mk2 gods  :evil: :evil: :evil:
Offline bodga
  • F reg GTI 16v
« Reply #68 on: 21 December 2009, 21:11 »
It seems to me that your heater matrix is partially blocked up. does the heater warm up again if you giver the golf a thrashing?
 Normally i would get the garden hose on one of the matrix pipes in the engine bay and flush it though but your foot well might get wet if the matrix is weak and break! :cry:
Offline leeroy20vt
  • h reg mk2 gti
« Reply #69 on: 21 December 2009, 21:20 »
might try that tommorow if it brakes il bypass it till i get round to fixing mind u the way its goin it will be very warm with a gallon of petrol and a match lol
