Author Topic: suspension/ brake questions  (Read 1491 times)
Offline danny_p
Re: suspension/ brake questions
« Reply #10 on: 13 November 2008, 21:05 »
disconnect track rod  from hub,  disconnect brake flexi ,  undo 3 13mm  bolts holding ball joint in wishbone,  undo two 19mm bolt holding strut to hub,  and then  lift, pull, yank or catch it.    do same to to other car fitting is reverse of removal
all the VW's have gone bar 1.
