Author Topic: Whine with revs (not gearbox)  (Read 2028 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Whine with revs (not gearbox)
« Reply #10 on: 12 November 2008, 15:02 »
Just take the PS belt off, start it up... see if it stops, then the same with the other belt.  If it stops then its either the Alternator, water pump or tenssioner.   Spin the pullys by hand and feel for groggly bearings and play in the shafts.   :smiley:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline oatmung
« Reply #11 on: 12 November 2008, 16:54 »
Sounds like a plan. Cheers!  :grin:
Offline bow
« Reply #12 on: 14 November 2008, 22:28 »
most likley the aux tentioner but cuold cam belt tentinor or even cam belt to tight
