Author Topic: Suspension problems  (Read 1987 times)
Offline Agreeable Slick
  • Unit
Re: Suspension problems
« Reply #10 on: 10 November 2008, 18:28 »
Not necessarily the shock, there is a tiny little circlip that sits on the top of the piston that can snap off, and as a result the car will start bouncing around. Great fun.
Offline Nate187
« Reply #11 on: 10 November 2008, 18:30 »
Go for Boge dampers they rock  :evil:
But thats what he is trying to avoid!! :undecided:
Lol. Boge gas dampers with your standard springs and your onto a winner.
Its not a Gti without the stripe
Offline Steve_B
« Reply #12 on: 10 November 2008, 21:18 »
How do I check this circlip thing? Had a look at haynes and it looks like I'll have to take the shock out just to see it.
Offline Diamond Hell
  • Opinions я Us
« Reply #13 on: 10 November 2008, 21:26 »
That's only the rears though...
  • Unit
« Reply #14 on: 10 November 2008, 21:45 »
correct, but as he didn't stipulate i thought i would mention it.
Offline Steve_B
« Reply #15 on: 10 November 2008, 22:39 »
Hmm, it does seem to be the rear ones that are gone so it's a possibility. Is it possible to find out by jacking the car up and shining a torch in there? Won't be able to look until the weeknd otherwise.
  • Opinions я Us
« Reply #16 on: 10 November 2008, 22:43 »
Take the cap off the top of the turrets and bounce up and down - you'll soon see if the circlips have failed.
  • Unit
« Reply #17 on: 10 November 2008, 23:41 »
to add to that, the reason why would be cos you will see the piston come shooting up through the hole.
Offline Steve_B
« Reply #18 on: 11 November 2008, 19:26 »
Do you just mean the rubber cap that sits on top. Surely if i start unscrewing the nuts on the top plate the suspension will collapse?
Have removed the caps and can't see anything moving, but then it all seems botled down anyway.
