Author Topic: *Shutting Boot*  (Read 2320 times)
Offline TheRaven
  • "I am female, I think the boobs are a giveaway..."
Re: *Shutting Boot*
« Reply #10 on: 07 November 2008, 14:37 »
You put the key in, turn it and the shaft (middle) of the lock turns 180. Then it opens.
Slam the boot and try it that way.
Professional Freelance Equestrian Photographer
www.ravenphotography.co.uk
www.ravenphotography.uk
Offline Agreeable Slick
  • Unit
Re: *Shutting Boot*
« Reply #11 on: 07 November 2008, 14:38 »
They rotate 180 degrees.
Sounds like the pins in the barrel are seized. scrappy trip for a new one methinks. Or a solenoid.
Offline luked
Re: *Shutting Boot*
« Reply #12 on: 07 November 2008, 14:43 »
Yeah- thats the problem. cant rotate the key in the lock. and its on the latch and wont shut.  :angry:
And there was me thinking my first thread on here would be a good one.  :grin: Cheers for help anyways.
Offline TheRaven
Re: *Shutting Boot*
« Reply #13 on: 07 November 2008, 14:59 »
Thats what everyones here for, oh and to chat sh!t all day lol!  :smug:
Re: *Shutting Boot*
« Reply #14 on: 07 November 2008, 16:11 »
I suspect the striker pin on the bottom of the tailgate opening has moved and now the boot catch cannot engage on it properly by the sounds of it, loosen the bolts and move it further upwards and retry.  There is also a rubber buffer in each corner of the tailgate, if these are wound out too far the boot wont be able to close enough to cathc the striker. If that doesnt sort it or the boot catch keeps sticking shut then you'll need to take it out of the tailgate and service it!
Pull the plastic trim off inside the boot, you'll see a metal rod linking the button to the boot catch.  It sounds liek somehow this is sticking or the boot catch itself is jamming up internally? its easy to strip it all off, theres 2 big allen bolts holdign the catch to tailgate, so remove that 1st and unclip the rod from the inside of the catch.  Now work the mechanism to see if its sticking, if the spring is good & strong and springs open nice when you release it all is well here, conventrate on the boot lock.
The lock pops out from behind, there are 2 clips that you release and it'll come out.  If you have central locking its a bit mroe tricky as it has the massive long bar to the cl actuator, but if you unscrew the actuator from the boot you can release it from the rod.  The rod will then come out, it'll take a bit of persuation and wiggling but it will come out in 1 piece!
Next check the lock mech, put the key in and spin it, you should see the lock mech spin and the metal mech on the rear of the lock moving round.  If the key doesnt move it or is jammed remove the screw from the back and withdraw the lock barrel.  Drown the lock barrel in penatrating oil til all the pins move freely, clean out the button hole it came out of and re-assemble.
Refit it all to the car and hopefully it should now work!
Offline luked
Re: *Shutting Boot*
« Reply #15 on: 07 November 2008, 17:00 »
Top stuff. Cheers dude  :wink:
Re: *Shutting Boot*
« Reply #16 on: 07 November 2008, 17:15 »
forgot to say, becarefull when the lock is removed as the pins will be free to fall out, or they should be if not stuck in with corrosion.  kep the key in though and they cant go anywhere :)
if you want to strip it down completly remove the key and pop out each lock finger, making carefull note of the order they go in, otherwise you'll have lots of fun gettin em back in the same order  :grin:
Each finger has 2 springs, so pull those all out too and dont loose any!  If you do manage to you'll need to find some more locks from de scrappy and pillage em for spares!
Once out give em all a good clean and test fit till they slide in and out smoothly.  Also if you stretch the springs a tiny bit this will bring new life into worn ones.  Put everything back in as you took em apart and refit key to cylinder, you should note that all fingers are flush with the barrel, if not your key is worn, its the wrong key or you messed up the order of the fingers.  Refit the lock barrel to the button and check it spins freely, if not pull the lock out again and recheck.
If you cant get spares or your key is too worn, you can file down the lock fingers till smooth, but if you have a spare ket this means it might not work in the lock!  Ideally you want to get a shiny fresh key cut rather than lock finger filing.  This also works if you strip another lock for spares and you cannot find the exact size finger you need for your key!  I retumbled a MK2 glovebox lock for my MK1 cabby main key this way, I got most of the fingers I needed but some needed a bit of filing for smooth operation :)
Offline Mr Blue
Re: *Shutting Boot*
« Reply #17 on: 07 November 2008, 17:53 »
while your at it...
on the two corners of the boot door you have two rubber stoppers.
Wind them all the way in and see if the boot closes.
Had a similar problem once mine came back from sprayers. Adjusted and then it closed.
