Author Topic: Mini Wheels  (Read 2262 times)
Offline Simon Mulley
Mini Wheels
« on: 06 November 2008, 18:42 »
Will a set of Minilites off a 1980 Mini fit a 1990 Mk2 Golf GTi ?
Offline filthy
Re: Mini Wheels
« Reply #1 on: 06 November 2008, 18:47 »
No....mini wheels are 4x4 inch, but Golfs are 4x100mm....close but no cigar!
You can get them to fit using spigot rings and wobble bolts
bit dodgy though...
you might need to grind a bit off your calipers as well...
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
Offline sidecarphil
Re: Mini Wheels
« Reply #2 on: 06 November 2008, 18:52 »
why would you want too ???
i'm guessing you don't mean 12" wheel's  :grin:
Offline adam_mk2
Re: Mini Wheels
« Reply #3 on: 06 November 2008, 19:10 »
they should fit, i had a set of 13" superlites from a mini on my golf for a while, and ive seen other people do it to! but being 12" i doubt they will clear the brakes on a gti
Re: Mini Wheels
« Reply #4 on: 06 November 2008, 19:14 »
I've just seen a set of 4 Minilite 7x13', they were cheap so I was just wondering
Offline Benrevs
Re: Mini Wheels
« Reply #5 on: 06 November 2008, 23:43 »
They fit with standard brakes and the weights moved. Spigot ring is all you need. Ben
Offline Horney
Re: Mini Wheels
« Reply #6 on: 07 November 2008, 00:04 »
And wobble bolts as 4x4" is not the same as 4x100mm as pointed out above. It's close but it's not right, you'll be bending your wheels bolts ever so slightly.
Nick
Offline Martz
Re: Mini Wheels
« Reply #7 on: 07 November 2008, 00:23 »
Nope, but BMW Mini wheels do with a small amount of work from a good machinist. Have a nice set of 17's that have been modified to fit. :cool:
Offline Benrevs
Re: Mini Wheels
« Reply #8 on: 07 November 2008, 04:28 »
oh,  they seemed fine?  Will put one back on and have a look! i honestly didnt notice. Cheers rj
Offline Diamond Hell
  • Opinions я Us
Re: Mini Wheels
« Reply #9 on: 07 November 2008, 09:45 »
M'mmmmm, smells like Vauxhall Carlton wheels on a Wedge.
