Author Topic: Gear Linkages  (Read 1846 times)
Offline Brads MK2 GTI
Gear Linkages
« on: 03 November 2008, 11:21 »
Hi peeps,
Is it possible that if the gear linkage is mis-aligned you could select the same gear in two posistions on the gear stick? My 4th and 5th gear seem to have the same ratio, same RPM at all speeds!
nige_s
Re: Gear Linkages
« Reply #1 on: 03 November 2008, 11:26 »
Something isn't right there, 3rd and 5th is an easy one for a worn linkage to give, but 4th and 5th is an odd one.
Re: Gear Linkages
« Reply #2 on: 03 November 2008, 11:29 »
Hmm that's not good then, was hoping it was likley to be that. :(
Offline Mr Blue
Re: Gear Linkages
« Reply #3 on: 03 November 2008, 11:35 »
I had a similar problem on a 16v.
There was a securing nut that worked loose. Sounds like the rod alignment is out.
Doesnt hurt to change the bushes. cheaper than a box!
Re: Gear Linkages
« Reply #4 on: 03 November 2008, 11:45 »
Well that's cool news then, I haven't looked into it yet, but everyone agrees that it is possible to select the same gear in two positions because of likage problems. I better get looking into it then!
Offline Mew
Re: Gear Linkages
« Reply #5 on: 03 November 2008, 12:38 »
Has it just happened or have you just bought the car?
Re: Gear Linkages
« Reply #6 on: 03 November 2008, 12:38 »
linkage faq ;)
could be the relay shaft ball has come off, or you have a cracked plastic ball end :)
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Gear Linkages
« Reply #7 on: 03 November 2008, 12:57 »
linkage faq ;)
What he said. Balls!
But also the linkeages, as has been already mentioned, could also be out of alignment. Even with the ball missing, you should still be able to select all gears, but the gearstick will feel like stirring a rice pudding.
Re: Gear Linkages
« Reply #8 on: 03 November 2008, 12:59 »
Yeah no I've had the car for a few years now. Must have happened recently ish, couldn't give an exact date as I rarely use 4th, normally block shift from 3rd to 5th and cruise in that! Although I do need to do a bit of work down that area anyway, you wouldn't believe the amount of sideways and up & down travel on the stick!
Re: Gear Linkages
« Reply #9 on: 03 November 2008, 13:10 »
yeah a mixture of relay shaft and worn under car housing I think!
