Author Topic: loosing water, thermostat not opening  (Read 1645 times)
Offline dubslug
Re: loosing water, thermostat not opening
« Reply #10 on: 02 November 2008, 13:58 »
when filling it up should thermostat be open or closed??
would need more water if open??
1992 pearl grey 8v
Offline Conker
« Reply #11 on: 02 November 2008, 14:09 »
You have to fill up from cold, otherwise you would have to run the engine with no/little coolant to try and get the thermostat to open... Unless you are flushing the system first, in which case the thermostat could technically be open when you refill, if you do it quick enough.
Fill it up cold and then follow the usual bleeding procedure until the thermostat opens, at which point the level will prob drop and you'll need to keep topping it up.
Squeezy squeezy pipe time   :wink:.
Offline dubslug
« Reply #12 on: 02 November 2008, 14:21 »
nice on cheers thought that was the case
1992 pearl grey 8v
Offline sidecarphil
« Reply #13 on: 02 November 2008, 14:41 »
what about a faulty presssure cap  :undecided:
could be throwing coolant out cos of that
Offline dubslug
« Reply #14 on: 02 November 2008, 14:51 »
its new vw one and blue....
was checked when h/g was changed a while ago
1992 pearl grey 8v
Offline sidecarphil
« Reply #15 on: 02 November 2008, 14:52 »
cool just an idea , oftern overlooked  :wink: :wink:
Offline dubslug
« Reply #16 on: 02 November 2008, 14:57 »
thanks, please feel free to offer as many ideas as u can, its new cap and resevoir..
i think the problem was down to thermostat as that definatly didnt open yesterday but after i re topped water up today it did, and there was no bubbling inside the resivoir
regards
1992 pearl grey 8v
« Reply #17 on: 03 November 2008, 11:14 »
coolant faq, have a read thru it it takes you thru how to test every aspaect of coolign system and proper method to bleed.  its in the mk2 faq atm, ive asked for it to be moved but its not happened as of yet!
