The garage
wheel bearings?
Topic: wheel bearings? (Read 4846 times)
golfvr6
Guest
Re:wheel bearings?
Reply #10 on:
06 June 2004, 21:12 »
I got the inner races out with my fingers on my Golf
Veedubgt18v
Guest
Re:wheel bearings?
Reply #11 on:
06 June 2004, 21:17 »
yep. once i took the split pin out and undid the castellated nut it all just came apart, putting the drum back together was a bit of a b!tch, i pinched my finger in the handbrake bit.
golfvr6
Guest
Re:wheel bearings?
Reply #12 on:
06 June 2004, 21:20 »
Except when you change the wheel bearings you do need to change the inner races, they are a tight fit, hammer and old shells work a treat.
They don't really come out with your fingers
Veedubgt18v
Guest
Re:wheel bearings?
Reply #13 on:
06 June 2004, 21:40 »
hmmm.....
mine were all skanky and didnt exactly fall out but they came off with a flat blade screwdriver wiggle job
Veedubgt18v
Guest
Re:wheel bearings?
Reply #14 on:
good job i changed them really
golfvr6
Guest
Re:wheel bearings?
Reply #15 on:
06 June 2004, 23:31 »
Yeah they must have been f**ked
The garage
wheel bearings?
