Author Topic: Project 16v  (Read 2386 times)
Offline MarkS
Re: Project 16v
« Reply #10 on: 27 October 2008, 21:35 »
http://www.halfords.com/webapp/wcs/stores/servlet/SearchCmd?srch=waxoyl&x=0&y=0&action=search&storeId=10001&catalogId=10151&langId=-1
People use it to protect metals from rust, and during winter people usually apply it liberally to the bottom of their car with a big brush to stop corrosion from all the nasty salt etc thats on the roads!
Also a lubricant too I believe :)
Offline hobbes
Re: Project 16v
« Reply #11 on: 27 October 2008, 21:43 »
Cheers for that.  so, if i take up the carpet is it best to paint some of this stuff on?  if i take up the carpet will i break any seal/foam/whatever underneath that will need repairing and/or replacing?
Mk2 Golf GTI 16v
Mk4 Golf GT TDI
Offline MarkS
Re: Project 16v
« Reply #12 on: 27 October 2008, 21:49 »
I'm not too sure about painting it on under your carpet but its a good idea to get actually underneath your car and apply it :)
I had to do it with a spray can and a cloth, not fun. Use a brush and put your car on axle stands so its stable :)
Offline danny_p
Re: Project 16v
« Reply #13 on: 27 October 2008, 22:21 »
still a fair bit todo.  good point about the carpet, the interior has a musty feel.
Oh dear! Get the carpet out for sure! If you've had a water leak then you'll probably have to replace the sound deadening, you can get replacement sound deadening from places like B&Q, get the builders grade stuff   :wink:
Went B&Q yesterday to get some of the above, they just scratched their heads in confusion! What would B&Q call the stuff???
if it's the stuff i think your on about,   it's soundproofing insulation  a type of itchy scratchy insulation  you put it inside stud walls.    comes in slabs   problem is it's 50+mm thick
all the VW's have gone bar 1.
