Author Topic: 1991 VW Jetta front wing  (Read 3383 times)
Offline Mr Blue
Re: 1991 VW Jetta front wing
« Reply #10 on: 25 October 2008, 22:48 »
Is that a genuine front grill?
go to the rear of the car. look down the side and the wing should look straight.
Should have about a few mm gap between the grill and wing
Looks like the alignment is well out. Pannel gaps take some time to get right!
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #11 on: 26 October 2008, 01:38 »
Before you do any complaining, you need to take 2 critical measurements! open the bonnet, check the area where the front panel (slam Panel) meets the wings, you should see the heads of 2x 10mm self tapping bolts on both sides of the car, these bolts hold the front panel, and the wings, to the inner wings, now notice between each of these 2 pairs of bolts is a hole that appears to do nothing, this is a 12mm body alignment data hole, and is the key to setting up the correct front end alignment
Here's what to do, you now have to measure diagonal alignment, with the bonnet up, find the rearmost, wing fixing bolt on the O/S of the vehicle, should be the bolt closest to the bonnet hinge, get someone to hold the end of the tape measure exactly in the CENTER of the bolt head, and not to move it! take the tape across to the N/S alignment hole, and measure to DEAD CENTER, It should read bang on 155cm In both directions!  VW give you +-3mm to play with here, any more than that, then you have problems! measure up, and let me know what you have, and I'll try and point you in the right direction
By the way, Jetta wings ARE different to Golf wings!, although they are the same part No, Jetta wings were tweaked on the production line for a closer fit around the grill :shocked:
Tom
Offline Mk2Kezza
« Reply #12 on: 26 October 2008, 23:33 »
Just out of curiosity then, a question..
If they were 'tweaked' on the production line, does that mean any Jetta ever repaired with a new wing (the wings having the same part number) after a bump, never looked right and straight again? :huh:
<br />Almost finished.....
Offline Thom89
« Reply #13 on: 27 October 2008, 00:03 »
I was waiting for that question!! I used to repair  lots of Mk2s Golfs while they were still in production, and wing fit around the grill was always pretty good, but for whatever reason never 100% perfect,   If the same repair was made to a Jetta, then the gap around the grill was always different to the Golf, but could be overcome by straightening out the radius a little.. so the problem was actually with the fault of the shape of the grill, and not the wings! it was just easier to adjust the wings,  rather than a moulded plastic part, so yes, there are plenty of Jettas out the with wings that have not been tweaked to fit the grill..
Tom
Offline Mk2Kezza
« Reply #14 on: 27 October 2008, 10:35 »
Ahh ok, so maybe the repair job done on dub_maniac's car isn't so bad after all then... :huh:
Offline Thom89
« Reply #15 on: 27 October 2008, 19:49 »
Hmm not really, look at his pic again, the bonnet to wing gap looks a little on the wide side.. hopefully it can be rectified by juggling with the bolts..
Tom
