Author Topic: difficult to engage first  (Read 2485 times)
Offline boneybradley
  • Back in a Mk3...
Re: difficult to engage first
« Reply #10 on: 16 January 2009, 11:01 »
different altogether...and much more difficult to change! ensure you get synthetic based oil too (i believe 75w/90 is correct? thats what mines got in anyhow  :wink:)
Offline Dec
« Reply #11 on: 16 January 2009, 11:02 »
Argh im getting so annoyed at this car!
Think ill just take it to my local vw/audi specialist and tell them to look at it. such a hassle :angry:
  • Back in a Mk3...
« Reply #12 on: 16 January 2009, 11:14 »
yeah mk3's are built really well......but were built backwords using really random/unique fitments!!
(actually all gearboxes are difficult for oil changes!!)
kells
« Reply #13 on: 16 January 2009, 11:28 »
Sorry to drag this up, but its hard for me to find 5th in my car (more bloody problems!) and sometimes Ive put it in 3rd by accident. Is it hard to change the Gear linkage and is it in the Haynes manual?
think you jus need to get used to the box matey, my gf does this in mine :rolleyes: :grin:
  • Back in a Mk3...
« Reply #14 on: 16 January 2009, 11:38 »
the wife changes from 2nd to 5th in mine.........luckily the low down torque stops the valves rattling  :cool: :cool: (hey am i bigging up the 8v again?)
Offline Dec
« Reply #15 on: 16 January 2009, 11:46 »
I hope it is just that I need to get used to it :sad:
This is pretty much what I sent to rubjonny :rolleyes::
Quote
The problem at the moment is that 3rd and 5th gears seem really close together so I accidentally put it into 3rd not 5th a fair bit.
Any Idea what this could be? I thought about the gear linkage but as its the 16V its a cable change. Is there an easy fix or do I need a new gearbox
Also, compared to my mk2, the shifter doesnt go as far left so could it be that it isnt aligned properly?
Sorry my description is a bit vague but if you have any ideas it would be most appreciated! Also if you need any pics taken or any more info Ill do my best
Think I explained the problem a bit better there :undecided: Going to have a play with the gear stick in my lunch I think.
Offline Dec
« Reply #16 on: 16 January 2009, 12:40 »
Too cold to go outside :tongue: Ill look later when I have to go out there!
Quote from: Bryn
If it's roughly the same as my Rado was (99% sure it is) there are slots in the cable ends where they bolt to the gearbox arm. As the cables stretch over time, you can adjust them using these slots. Just position/lock the gear stick, crack off the bolt and adjust with a bit of trial and error.
Thats what my mate said on another forum, hopefully thats all that needs doing :smiley:
Another guy also said this :lipsrsealed:
Quote from: dannymcflylol
lol you're such a worrier :D it'll be easy im sure.
Which is 110% true!
I even looked on autotrader for another 16v so I could just swap my leathers and other bits over :rolleyes: If it goes wrong ill fix it, proberly cheaper than another car anyway!
kells
« Reply #17 on: 16 January 2009, 13:17 »
gears are alot closer together in GTI's than what they are in non GTI's if that makes sense, i remember having my escort runner, it was like havng each gear 3 mile apart from eachother, see iv always had GTI's right from learning to drive..so im used to the close ratios..but i can imagine it taking some getting used to, they are quite close on the golf..
Offline Dec
« Reply #18 on: 16 January 2009, 13:39 »
Ah right, I was thinking about it and my mate who drove it back for me didnt have any problems so thought I had messed it up somehow!
Ill get a couple of my other mates to have a drive and see what they think :smiley:
Offline VR6-Joe
« Reply #19 on: 16 January 2009, 16:16 »
Dec if you're having problems I'll happily do a straight swap for my Mk3 :grin:
It's been to Wales and back in a day with no problems whatsoever so it's a reliable one :grin:
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
