Author Topic: Braking  (Read 2944 times)
Offline RedRobin
Re: Braking
« Reply #10 on: 25 October 2008, 09:41 »
As for mods, no mods for a minimum of another ten months!
....One of the best mods you can do is driver training - Remapping your brain. :afro:
Offline dan_apps
  • too low for british roads!
Re: Braking
« Reply #11 on: 25 October 2008, 09:42 »
if in a spot of trouble ive tended to use the gearbox to slow down....i know not a good idea as gearboxes are more expensive than breaks!
WhiteGTI
Re: Braking
« Reply #12 on: 25 October 2008, 09:45 »
Good analogy..!
Offline RedRobin
Re: Braking
« Reply #13 on: 25 October 2008, 10:28 »
....I always work down the gearbox simply to be constantly in an appropriate gear to match speed. In other words to be able to slow or accelerate instantly if needed. Modern engine braking is less 'powerful' than it used to be - Once upon a time brakes were so bad that engine braking was essential!! I'm reminded of trying to stop several tons of 1940's Rover downhill entering a town on drum brakes!
One of my driver training courses has taught me to use the gears even more than I used to. DSG gearboxes are potentially much longer lasting than Manuals as they have built-in self-protective mechanisms as opposed to suffering human misuse. [in my opinion!]
Offline stealthwolf
Re: Braking
« Reply #14 on: 25 October 2008, 11:16 »
I've done this when needing to slow down rapidly but not emergency stop. I'll shift down the gears to second whilst the brakes are applied continuously. I also try and avoid the need for it.
What I'm still trying to learn is the best shift points for each gear so when I downshift, I match the revs. I did ask about it in another thread but no one answered!
Offline k4ith
Re: Braking
« Reply #15 on: 25 October 2008, 15:04 »
R/R is bang on, there is no point having a 200-300bhp fast road car and not know how to use it safely/properly.You have to drive to the road conditions, slow in fast out, look through the corner to the exit, smooth with go pedal and with the brake.
MKV Golf GTI Edition30, GIAC Pump&Race Map, AutoTech Fuel Pump, R32 Front Brakes, Dbilas Flo-master Intake, S3 Intercooler.ECS Dog Bone Insert.
MKII GTI 8v Tornado Red 88 - Das Projekt
