Author Topic: abf into mk2 conversion  (Read 1013 times)
Offline Mattudor
« on: 21 October 2008, 16:34 »
What exhaust system do I use? will it have to be a custom jobbie? Im guessing custom manifold with a mk2 aftermarket system?
If thats true any ideas how much a custom manny costs?
Re: abf into mk2 conversion
« Reply #1 on: 21 October 2008, 16:49 »
OEM MK2 16v will fit perfect, all you need to do is have a lambda bung welded into downpipe if you plan to run it on ABF managment.  Or swap the downpipe for a MK2/Corrado G60 item, plus cat or a cat bypass. Bolts right to std 16v manifold and front silencer and has lambda bung already in place.
P.S. ABF manifold is the same as a MK2 16v one, and also Corrado/Passat 9a manifold will also work :)
« Last Edit: 21 October 2008, 16:51 by rubjonny »
Offline Mattudor
« Reply #2 on: 22 October 2008, 10:13 »
sweet, thanks a lot :)
so It's literally a straight engine swap... no other shenanigans required?
« Reply #3 on: 22 October 2008, 10:18 »
the short answer is, it depends!
what engine do you have now, and wat managment did you want to run the abf on?
Offline danny_p
« Reply #4 on: 22 October 2008, 19:21 »
ABF swap isn't exactly a hard install.       useing the EFI is easyer in the long run  k jet easyer in the short term if the car allready has it
all the VW's have gone bar 1.
